Bleeding brakes on yamoto 150
You bleed them the same as any hydro brake.Open the bleed valve,squeeze and hold the brake,tighten the bleed valve and release the brake.Repeat until you get a constant flow of fluid and no air then tighten the bleed valve completely.If u r having problems with the brake it may be do to bad o ring seals between the 2 halves, i had to replace mine right out of the crate.
I do all of my brake bleeding with a mighty vac brake bleeding tool. It sucks the fluid thru the lines from the master cylinder. You connect it to the caliper and keep filling the master cylinder as it empties.
my rear disc brake keeps locking up, i removed the pistons and polished the edges and they seem to seal well and don't get stuck. bled the system through. etc. can't think of anything else. works ok for a while, but it's like the fluid isn't moving back from the caliper... any ideas would be greatly appreciated!
thanks mywifesquad, seemed that there was dirt fragments in the master cylinder that were letting fluid in but then blocking it from exiting, all fixed now and i upgraded those appalling pads for proper ones. all working...
Glad to hear it paulmurphy777, more than happy to help when I can.
And I almost forgot. Welcome to the forum. [img]i/expressions/face-icon-small-smile.gif[/img]
I just bleed the brake on a 150cc atv yesterday.Bleed the master at the line,cracked the line at the caliper-no air,but still very little brake.Yhen looked at the bleeder-it is at the bottom of the caliper-AIR CAN'T GET OUT AT THE LOWER-IT NEEDS TO BE AT THE TOP-unbolted the caliper,made sure the rotor was between the pads,bleeder at the top and bleed-done
kbazzy
Sep 26, 2015 11:26 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
