Ruby-Best gear for Hills?
Old Oct 17, 2000 | 07:20 PM
rockscott's Avatar
I rode up sever steep hills this weekend and tried it in Low d1 and Drive D1. It definately worked better in Low for the really long steep ones. What do yawl use? Should I have been in Low D2?, or esp?
Old Oct 17, 2000 | 09:54 PM
P.J.'s Avatar
There is no difference between Low D1 and Low D2. I use Low Auto, not Low ESP on hills.....gives me time to day dream.
Old Oct 18, 2000 | 12:14 AM
GabooN's Avatar
HI,
I use low auto for steep inclines, I am too big for D1 when going up a 45degree hill/Mountain.
-RubicoN
Old Oct 19, 2000 | 12:32 AM
rockscott's Avatar
when do you use d2?
Old Oct 19, 2000 | 10:05 AM
TEXMud's Avatar
D2 mode can be selected in High. I have still not figured out when I am supposed to be in D1 or D2. I fully understand what the modes mean but I just dont know when I use them.
Old Oct 19, 2000 | 07:54 PM
rockscott's Avatar
Hey Texmud
Yeah--I understand d2 is supposed to be for torque. Seems like you would need torque in low when you are hauling or pulling. When you figure it out, let me know.
Old Oct 20, 2000 | 03:28 PM
RubiconBob's Avatar
Guys, over 200 miles on my Rubicon, so I have some experience on this issue. Anytime you use Low, it automatically switches the drive mode to D2 (and you won't know it). If you need the low gearing, you would also want the extra torque from D2. D2, when selected (in High), changes the shift pattern of the tranny, allowing it to stay in gear longer (at higher RPM), where it can take advantage of the torque of the motor. It also shifts a little less often, so as to keep your momentum going. D1, on the other hand, always try to get in optimal RPM/gear for the speed and conditions (engine heat, throttle amount, etc). Here's my recommendations: D1 & High for normal driving when riding single, D1 & Low for serious inclines and hills (still riding single). D2 whenever you're riding double, hauling a heavy load, or other type of work for the ATV (like plowing). ESP for whenever you want to control the transmission, like staying in a specific gear. I don't use ESP much, because the tranny is that good......
Old Oct 20, 2000 | 08:51 PM
rockscott's Avatar
Hey Bob--Thanks for the explanation
For some reason I can't recall ever using or trying d2 yet. I think I might have tried it once and didn't notice much difference. I'll try it tomorrow and see if I notice.
Thanks
Old Oct 21, 2000 | 06:30 AM
gassygordo's Avatar
I have 720 miles on my Ruby and must be my D1 and D2 are reversed. I use D2 for easy riding through the woods to keep my rpm's down, my noise down and my gas mileage up.When I'm climbing our greasey clay hills I use D! for more rpm's and more power. When I'm wearing my heavy 26" Vamps on steel wheels in deep sticky mud, I use ESP low range.
2quiker
Mar 22, 2022 08:36 PM
merryman
Jan 19, 2016 04:29 AM
Haakon
Aug 24, 2015 01:54 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
