Handguards for Eton 90?
send me your email and i will send you the link to the album they are in
markvette@bellsouth.net
may try one more thing
Looks good..Thanks for all the help..Just ordered the handguards and will be ordering the nerf bars and bumper very soon.
What size wheels/tires are you running on the front? I have 16x6.5-8 all around right now, had them along with spacers added on before I left the dealer with it. I went with the same all around because most of the front runners around here (flat track) run the same size. I may go with different fronts when I get into suspension upgrade which I wanna do before I get into any power ups.
I do want a little sound so what would you reccomend as a good clutch, exhaust combo?
the fronts are 19x6x10 holeshots. we run mx and the taller tires dont drop down into the smaller ruts. wrh on the pipe and clutch kit. he sells a whole new clutch that weighs about half a stock clutch. rollers will depend on a lot of things, anywhere from 5.5 to 7 gram rollers. i run 6 gram but am running a 112cc stroker/big bore motor in my sons eton. a pipe and a clutch will make a world of difference. alos a bigger carb, i run a 28mm on the stroker but a 20 or 24 would be good for a milder motor. my sons eton rips, it will blow away a warrior or 300ex in a 200 foot drag race. i also run plus 3 a-arms with long travel shocks, the rear has a plus 3 swing arm with a fully adjustable 10 1/2" shock. i just ordered a fully adjustable works 13" rear shock and having a custom plus 3 swing arm made for the longer shock. the mods are endless for these quads. the rear also has 2" wheel spacers but they will be off soon as they now make a plus 4 axle for the etons. holler if you need anymore help.
Mark
Mark
