belt slipping on hills
Old Aug 8, 2005 | 04:56 PM
fishing's Avatar
Default belt slipping on hills
I have always had a problem with the belt slipping on my 03 scrambler. When ever I'm climbing a mountain and come up to a rock The belt will start to slip. This only happens when I start from a stand still. I've changed belts, I've changed springs and still the same thing. Let me tell you its a little bit embarrassing to have to get help from other rider because my peice wont go over a 10" rock. any advise?
Old Aug 8, 2005 | 05:17 PM
MnFriesen's Avatar
did you change just the primary spring, or did you change out the secondary too?
Old Aug 8, 2005 | 05:33 PM
spyder6's Avatar
are you useing low? [img]i/expressions/face-icon-small-blush.gif[/img]
Old Aug 8, 2005 | 05:35 PM
fishing's Avatar
both springs green and lavender. What is low O?
Old Aug 8, 2005 | 05:38 PM
BikKat's Avatar
Scramblers do not have Low . . .
SLG
Old Aug 8, 2005 | 06:34 PM
spyder6's Avatar
thats what i thought, sorry for asking
Old Aug 8, 2005 | 07:00 PM
Polaris500HO4x4's Avatar
have you changed your belt maybe its time for a new one
otherwise your clutch may be warped from overheating
Old Aug 9, 2005 | 12:50 AM
fishing's Avatar
Yes I'm on my 4th belt....
Old Aug 9, 2005 | 01:10 AM
JEFF10049's Avatar
Did you wind the secondary clutch spring when you put it in not doing this will cause slipping...
Old Aug 9, 2005 | 01:13 AM
JEFF10049's Avatar
2/3 of a turn in the clockwise if I remember right.
