eton blowing fuses
Old Aug 9, 2005 | 01:42 AM
stinkystarfish's Avatar
Default eton blowing fuses
hey guys any ideas on where to start with my sons eton 70 blowing fuses with the electric start it works fine with the kicker but just fryes the fuse at the battery with the electric start
also who makes a good kicker for this bike
Old Aug 9, 2005 | 08:16 PM
eton150's Avatar
First i heard of the fuse blowing but you might try the ign. switch
Old Aug 10, 2005 | 10:59 AM
thanks i will try that
Old Aug 10, 2005 | 02:09 PM
hondabuster's Avatar
If its blowing fuses, it means theres a short between the fuse and the load, or the load is bad. Disconnect the wire at the starter, and then see if the fuse still blows. If it does...definent wire problem...wire pinched, or rubbed bare and is touching the frame. If it doesnt blow, then have the starter tested, the brushes could be worn .
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Minimod
Sep 10, 2015 09:20 PM
