05' KODIAK 450 tires?
Old Aug 9, 2005 | 09:00 AM
StrayKat's Avatar
Default 05' KODIAK 450 tires?
I was wondering if anyone knew what is the biggest size ITP 589's I can run on a stock machine without rubbing. My brither has a 2000' kodiak 400 and the ITP 589's in 26" rub alot. I also want to run type 5 ITP rims, thanks for the input...
straykat..
Old Aug 9, 2005 | 12:46 PM
kawasaskirules's Avatar
you can put 26's on it maybe not 27's then you would prob need a lift kit
Old Aug 10, 2005 | 12:36 PM
GrizzlyFD's Avatar
The 2000 Kodiak 400 is a much different machine than an 05 Kodiak 450.
One way to test what tire size would fit your machine would be to try and get the suspension to flex all the way and see where the tires come close. (you may need to remove the sway bars to do this)
Just a note: if the tires rub a little plastic, after a couple time riding the tires will have removed just the right amount of plastic so as to not rub anymore...and it doesn't look that bad actually...
Also you might want to consider the type 6 rims instead of the type 5...check out the thread ITP type 5 or 6...
Matt
Old Feb 5, 2006 | 03:08 PM
quadman3's Avatar
i just got 26"itp 589's c ceries rims and there is no rubbing i dont have a lift or nothing on it and my 05 kodiak 450 with ic for my brother im positive they will fit
o4 suzuki eiger
2002 yamaha kodiak
3000lb venom winch
26" 589's[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 15, 2006 | 12:15 PM
squeege's Avatar
same here, type 5 itp 26x12x12 rear 26x12x10 front mudlights no lift works fine see pics
Old Feb 15, 2006 | 05:48 PM
weaver's Avatar
27inch tires will work thats what i have on my 05 with no lift on it
Old Feb 18, 2006 | 10:23 AM
MudDawg450's Avatar
StrayKat
I am running 27” 589’s on my 450 with the stock rims. Haven’t had any troubles even berfor i put the lift on.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
fd24
Jan 16, 2019 08:59 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
