Banshee pilot's:rich or lean?
Old Aug 10, 2005 | 01:44 AM
rotty150's Avatar
Default Banshee pilot's:rich or lean?
I just put on some keihn 35mm pwk carbs and it has a dead spot on the bottom end. If I'm in the power band it does fine at an idle if I punch it it will die or bog out then rev. Mains seem to be fine at 160. pilot is at a 78, air/fuel mix are 1 3/4 out. I am at elevation 2000ft. Does it sound like my pilot is to rich or to lean? thankx
Old Aug 10, 2005 | 06:38 AM
enFORCER's Avatar
When I was runing a 350 on gas I had keihin 30mm pwk's.... Biggest mains I ran were 154....
Now having said that, I think your pilots are to big as well... Try dropping them down a few sizes...
My 350 was ported and I am at 472ft. above sea level......
Old Aug 10, 2005 | 11:42 AM
AlkyBurninX's Avatar
Drop your pilots to a 55. 160 on the mains is about right.
Old Aug 10, 2005 | 01:22 PM
Christopher's Avatar
Your bog can be caused by one of the following:
-Carbs not in sync
-pilot jet clogged or to small
-Needle to lean
Chris
Old Aug 10, 2005 | 08:27 PM
rotty150's Avatar
thankx guys I'll fatten up the pilot, if it gets worse I'll drop it to a 55...
Dammar
Apr 20, 2016 06:03 AM
QuadRiders
Oct 22, 2015 04:13 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
