ELECTRIC STARTOR
Old Aug 10, 2005 | 01:59 AM
trailblazermudrunner's Avatar
Default ELECTRIC STARTOR
WHERE IN THE HELL IS THE STATOR ON A 2000 TRAIL BLAZER 250 AND WILL A 2003 TB STATOR FIT A 2000 HELP[img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 10, 2005 | 02:11 AM
Bretman's Avatar
1. i think its somwhere in the part where you pull start. its somwhere around there if that helps.
2. yes it should fit, they really didnt change anything on the models so it should fit.
Old Aug 10, 2005 | 02:25 AM
but when ever i try the electric i hear a tickin comein from the some place near the clutch but i need a new pull coard any way so can some one tell me how long the rope shold be?
Old Aug 10, 2005 | 11:49 AM
lslubecki's Avatar
Are you talking starter or stator? Stator is behind the pull starter. Starter is under the engine I think. If you are hearing ticking when you try to start it you might just have a dead or weak battery. Or the stator may not be charging the battery when the engine is running.
Steve Lubecki
Old Aug 10, 2005 | 03:16 PM
cornbread2's Avatar
Most of the time you don't have to buy a $300 starter.
Useally all they need is new brushes installed in your old starter.
If I remember correctly brushes are about $30.
Old Aug 10, 2005 | 06:15 PM
im not gonna buy a new starter im gonna swap them out on a 2003 i think it is
Old Aug 10, 2005 | 06:17 PM
Steve Lubecki
im talkin about the the electric starter i replaced the batt when the starter when i just need to know or have a cut out of were it is so i can swap them out and im good to go?
Old Aug 10, 2005 | 07:43 PM
lslubecki's Avatar
I am sure they will swap out ok. But check www.partsland.com and it will give you part numbers of both starters.
Steve Lubecki
Old Aug 10, 2005 | 11:28 PM
rieds's Avatar
the starter is in between the tranny and crankcase on the bottom side. pull your belly pan off and you will see it. i'm not sure if a 250 is the same as a 400 but if it is you have to pull the pull start cover off to get to 2 bolts that hold the starter on. then you have to take off the clutch cover, pull the secondary clutch, take out the three bolts that hold the back clutch cover to the frame then pull the the back clutch cover up and rest it on the tranny ahaft so you can get to the other 2 bolts that hold the starter on. if someone knows an easier way jump in here. by the way do you turn your fuel valve off when your not riding? if not the needle valve seal wears out from the weight of the gas in the tank constantly pushing on it so when the bowl fills up it runs out the drain hose and down on your starter and ruins the rubber seals on the starter and then the gas runs inside the starter. this is what my dealer told me causes almosr every bad starter he replaces.
Old Aug 10, 2005 | 11:30 PM
rieds's Avatar
all yeah i forgot to mention that you can by a brand new starter from www.mfgsupply for about 120.00 delivered to your door. supposedly there not as high quality as the original but i've had mine for three years withiut a problem yet.
