Water in the clutch cover
Old Aug 11, 2005 | 11:27 AM
Murph22083's Avatar
Default Water in the clutch cover
My lady friend has a 2005 Kodiak. She found one hell of a deep water hole last weekend and completely filled up her belt case with water. Other than draining it, should I do anything else to make sure it is ok? Thanks ahead.
Old Aug 11, 2005 | 12:13 PM
GrizzlyFD's Avatar
Was it just water...or did your lady friend fill it with mud/dirt/silt/water...If so then take the cover off and see how much debris was collected inside the case. If there is a lot of crap inside than you will probably have to regrease the bearings inside the primary and clean the v-belt and tensioners.
Matt
Old Aug 11, 2005 | 01:03 PM
Murph22083's Avatar
The water she got into was sandy/silty. Looks like I have something to do this weekend.
Old Aug 11, 2005 | 04:38 PM
GrizzlyFD's Avatar
An easy way to check how much debris she got in the case is to take off the drain/check plug on the front air vent. If that is full of dirt then yes...you do have some work to do this weekend...
Also, check the top speed/acceleration of the machine now that everything is dry. If there is dirt in the bearings your machine will feel slugish and the top speed will be drastically reduced.
Matt
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
ghost civic
Jul 15, 2015 10:48 PM
