Water in the clutch cover
Was it just water...or did your lady friend fill it with mud/dirt/silt/water...If so then take the cover off and see how much debris was collected inside the case. If there is a lot of crap inside than you will probably have to regrease the bearings inside the primary and clean the v-belt and tensioners.
Matt
Matt
An easy way to check how much debris she got in the case is to take off the drain/check plug on the front air vent. If that is full of dirt then yes...you do have some work to do this weekend...
Also, check the top speed/acceleration of the machine now that everything is dry. If there is dirt in the bearings your machine will feel slugish and the top speed will be drastically reduced.
Matt
Matt
