'97 Wolverine Looses Power
Old Oct 18, 2000 | 10:20 PM
Gary709's Avatar
I have a '97 air cooled quad and when my quad heats up after riding for an extended period of time I loose power. Even going up small hills I have a hard time. Can anyone give me an insight on what might be the problem and/or to fix this problem.
Thanks in advance for any insight on my quad's problem.
Old Oct 19, 2000 | 11:12 AM
Quaddad's Avatar
Gary: Does the oil temp light come on while riding? If it does then you either need to clean the oil cooler fins out with a hose or pressure washer or car wash. We race a 505cc modified Wolverine in GNCC Cross Country and had a similar problem at the start of this race season. We corrected it by installing a larger oil cooler. You may also check the carb vent tube and gas cap vent tube for dirt or restriction. This will cause a fuel starvation problem which will appear as a loss of power. Yamaha now installs a small screen in the carb vent which you can buy and install in you quad to prevent dirt in the carb vent. Hope this helps.
Old Oct 19, 2000 | 05:16 PM
hot_shoe_cv's Avatar
If the above suggestions don't solve the overheating problem, you may want to do a plug read to see if the jetting is on the lean side, which would cause overheating and subsequent loss of power also
scram5050
Aug 30, 2024 01:39 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
315blaster
Aug 8, 2015 08:13 PM
Gtsordo
Jul 22, 2015 01:27 PM
tweeder
Jul 5, 2015 01:57 PM
