2005 700 EFI Power Commander finally available
Old Aug 13, 2005 | 10:50 PM
elkbow's Avatar
Default 2005 700 EFI Power Commander finally available
Dynojet finally has the Power Commander availabe for the 2005 700 EFI....anyone thinking of getting it?
dave
Old Aug 13, 2005 | 11:20 PM
arkmudder's Avatar
been seriously thinking about it. My buddy has been doing some research on them for his 800 efi and, it is supposed to increase hp by up to 20% and increase top and lower end throttle response as well.
Old Aug 13, 2005 | 11:41 PM
jefffoxsr's Avatar
What parameters can be adjusted and how are they adjusted?
Thanks.
Old Aug 14, 2005 | 12:41 AM
elkbow's Avatar
Thanks.
Jeff, don't think much can be adjusted other than fuel curves. Not sure how user adjustable they are, I know they list preset settings. It is a USB model, but I haven't seen them come out with an add-on for any ATV's to adjust timing, etc.
dave
Old Aug 14, 2005 | 01:41 AM
spyder6's Avatar
you can adjust everything within the powercommander and save it permanently according to my dealer
Old Aug 14, 2005 | 01:52 AM
elkbow's Avatar
yes, but only fuel curves...not timing...if they made the add-on for timing, then I would probably spring for one...
Old Aug 14, 2005 | 10:13 AM
jefffoxsr's Avatar
Thanks.
The ability to adjust the fuel curve it nice.
The ability to adjust the timing would be very useful. Timing adjustments significantly increase horsepower if you can accomodate for the changes and run without detonation.
Old Aug 15, 2005 | 11:03 AM
Speedwerx's Avatar
I would be surprised if anyone made a complete cdi unit for any efi model there is way too much going on with the efi's. You can change the timing on the efi's though with timing keys they are only like 16.00 each and yes we have them. A ? for you guys can you only add with the power commander or can you remoive fuel if needed?
Old Aug 15, 2005 | 12:08 PM
johnnybubu's Avatar
Does anyone know if ti will work on the 700 efi ranger xp?
Old Aug 15, 2005 | 07:24 PM
Speedwerx's Avatar
It should but if you want more perf. out of your ranger xp you should put the cdi box off of the 700 sportsman efi on it.
