03 700 SP Won't Start - engine turns but no spark
Old Aug 14, 2005 | 04:47 PM
78Bronco's Avatar
Default 03 700 SP Won't Start - ???
I finally installed the White Bros silencer on my 03 700 and now the dang thing won't start. It turns over but there's no spark.
I've checked the resistence of the exciter and pulse coils at the connectors to the CDI box as well as the coil ground to the engine and everything reads within limits. I ran into problems when I checked for cranking voltage output for the exciter and pulse coils. The voltage should be 34 VDC for the exciter and 3.3 VDC for the pulse but I'm only getting low mV readings.
Any suggestions as to where I should go next?
I'm thinking I'll need to pull the stator cover and housing but I don't know what I'd be looking for other than cut/bare wires and a correct trigger coil gap.
Any help well be appreciated.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Thanos
Jul 12, 2015 08:40 PM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
elmer119
May 24, 2015 10:51 AM
