front axle bearings
Old Aug 16, 2005 | 09:51 PM
angler's Avatar
Default front axle bearings
Where can I find front axle bearings for a 05 Rubicon? I can't find them at Rocky Mountain.
Old Aug 16, 2005 | 10:37 PM
Quadfather's Avatar
try
www.planethonda
or
www.servicehonda.com
Old Aug 16, 2005 | 11:40 PM
LittleBill's Avatar
its an 05, i can't possibly see that being a wear item, check warrenty, but i have a feeling its just dirt in the shock towers, if u run through high water and come out does it go away?
Old Aug 17, 2005 | 11:12 AM
recon99's Avatar
I agree front axle bearings should last at least 5 years on a utility quad unless the seals went bad and mud got in there, in which case it should be covered by the warranty if it hasn't expired yet.
Old Aug 17, 2005 | 11:31 PM
angler's Avatar
I am not sure if its the bearing but it is making a squeaking noise where the boot goes into the gearbox. It's not real loud but you can hear it. The only reason I'm worried about is because I am going to Utah September 2 and do not want to break down on the trail. That why I think I am going to bring a bearing with me so if I do break down I can fix it.
Old Aug 18, 2005 | 09:04 AM
recon99's Avatar
If it was the bearing the wheel would feel a little loose and rattle if you have the front end lifted up and you shake the wheel. If it's squeaking you probably just need to grease the seals around the boot.
Old Aug 18, 2005 | 04:10 PM
angler's Avatar
I'm sorry I was talking about the wrong thing. The differential bearing is squeaking.
Old Aug 18, 2005 | 06:44 PM
recon99's Avatar
I never heard of a differential bearing wearing out since there's not much stress on them. If it's squeaking it's probably just that the seals are dry and need greased. If you can't get in to grease them try wd-40 instead.
Old Aug 18, 2005 | 11:24 PM
angler's Avatar
Do you have to tear it down to grease or spray it? I don't have much time right now.
Old Aug 19, 2005 | 11:04 AM
action450s's Avatar
No just spray some aerosol lubricant in there to stop the squeek. Its not a problem with regards to breaking down, just an annoyance.
Ean
Dec 19, 2022 08:48 AM
JackTheKing
Jul 14, 2015 09:09 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
Rider252
Jul 6, 2015 03:37 PM
