AC 650 jumps out of high range
Old Aug 18, 2005 | 04:56 PM
petroleumboy's Avatar
Default AC 650 jumps out of high range
Has anyone had any problems with their machine jumping out of gear? I shift from neutral to high range on my 650 and once the machine hits about 15 mph, it jumps back to neutral. I assume I need to adjust the linkage but is it field adjustable or better left for the garage at home?
Old Aug 18, 2005 | 08:29 PM
Chumley's Avatar
Don't push the shift lever all the way forward, pull it back just a hair, you should be able to feel where it wants to be.
Old Aug 18, 2005 | 08:57 PM
heyyou's Avatar
Put it in high gear,take the seat off and loosen the two torx screws on the shifter linkage and then wiggle the arm on the tranny a little to make sure it is centred in that gear and tighten it back up.That is your problem I'll bet,if it doesn't work,keep trying,it took me a few trys to get it right.Darn thing would jump out of gear all the time,usually when I was cranking on it too.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Aug 19, 2005 | 01:32 AM
bfb750BF's Avatar
heyyou is correct.
It is just your linkage adjustment. A friend of mine had problems with his kicking out of low range. We were able to fix it on the trail & that was 700 miles ago.[img]i/expressions/face-icon-small-smile.gif[/img]
Nondem
Feb 22, 2020 12:20 PM
peytonius
Sep 28, 2015 02:18 PM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
