Blaster Carb help
Old Aug 19, 2005 | 12:51 PM
brlatm's Avatar
Default Blaster Carb help
I have a 94 Blaster with a big bore kit stock carb and other go fast goodies. I recently moved to WY and now the thing is really hard to start and when you do get it started you cannot give it any fuel or it will die. any help would be great and oh by the way the elevation is the same as the last place I left and the gas and oil mix are brand new
Old Aug 19, 2005 | 01:20 PM
brlatm's Avatar
come on somebody help me I would love to be riding this afternoon
Old Aug 19, 2005 | 02:42 PM
fastblaster00's Avatar
how long has it been since u rode it befor it gave u trouble. and are u sure the elivations are the same. u need to get rid of that stock carb and go with a bigger one
Old Aug 19, 2005 | 02:43 PM
did it ever run good after u did ur last mod.... and what were the last few mods u did and when did it start acting up.
Old Aug 19, 2005 | 02:58 PM
brlatm's Avatar
All mods were put on at the same time and it was running perfectly, I checked the elevation with a gps and they are within 50 ft of each other. I got it here and I ran it 5 mins then I stopped to do something when I went to fire it back up it started acting up. It takes a whole lot of kicks now and when it does idle it is smooth it is when you try to give it gas that it bogs down. It used to take just one kick and then it would fire right over. I just pulled the carb and cleaned it it is a 340 main and 30 pilot with a b8eg plug. plugged smells fouled like it has way to much fuel it is black and wet.
Old Aug 19, 2005 | 11:01 PM
Storj's Avatar
you might have a bad float in your carb it maybe sticking open and flooding your engine it also sounds like you are to rich lean it up a bit
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
joeyupton
Jul 14, 2015 11:51 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
