Just Re-Jetted, need some help!
Old Aug 21, 2005 | 05:02 PM
2FAST4U69's Avatar
Default Just Re-Jetted, need some help!
I just put on an lrd pro4 full system, sixsixT intake. I rejetted it last night, I put 160/165 mains, and 127.5 pilots. and didn't touch anything else. When I took it down the road and opened it up, it seemed like it was choking on the top, it sputtered a little bit and seemed like there was a major power loss... any advice that anybody can give me would be very much appreciated.. thanks,
Scott
Old Aug 21, 2005 | 06:40 PM
Fahq's Avatar
You're too lean. If you piped it and modded the airbox, you will need more fuel. I am running 165/170 on mine. You may also want to check the pipe manufacturers website. They usually have jetting specs.
Old Aug 21, 2005 | 06:51 PM
sixsixT's Avatar
I agree with ^^ I would put 165/170 and just over 2 turns out on the mixture screws. Make sure your floats are set correctly.
Old Aug 21, 2005 | 07:33 PM
2FAST4U69's Avatar
Not too good with carbs... are those mixture screws directly on the bottom in front of the bowls? and how do I properly seat the floats?
Old Aug 21, 2005 | 07:36 PM
2FAST4U69's Avatar
Also are the single edelbrock carbs a good replacement? I dont really like the way these are set up.. Thanks,
Scott
JohnnySplat
Aug 6, 2015 12:07 PM
SMW
May 18, 2001 04:40 PM
ssimons
May 20, 2000 10:08 AM
tomuchfun
Mar 16, 2000 06:20 PM
