clutch cable
Old Aug 25, 2005 | 10:59 PM
warriorryder's Avatar
Default clutch cable
Hi
What do you have to do to change the clutch cable on a 95 blaster? Is is hard to do or simple? Just wanted to know because the little circle piece where it hooks onto the lever broke off so I have to replace the cable and I want to go riding this weekend
Thanks in advance
Old Aug 26, 2005 | 12:51 AM
bump
Old Aug 26, 2005 | 09:43 PM
doesn't anyone know
Old Aug 26, 2005 | 11:43 PM
recon99's Avatar
It shouldn't be too hard to do. I don't know exactly how it works on a blaster, but if it's similar to the warrior you start by disconnecting the cable from the mount by the clutch cover, then when that end is loose you should be able to turn the adjustment **** things on the clutch perch so that the cutouts on them line up and thin part of the cable slips through them. Then slip the cable out of the slots in the lever and pull it through. Pay attention to how the cable is routed so that you don't get kinks and stuff with the new one, or just tape the new one to the old one end to end and as you pull the old cable out the new cable gets pulled straight through(I think that will work)
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
craacker
Sep 9, 2015 04:32 AM
cdstang
Aug 31, 2015 07:52 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
