1989 Suzuki LT80 starting problem
Hey, I was wondering if anyone can help me. The starter will not turn over the engine. The battery is charged, the starter relay was replaced with a new one & all it does is click the relay. When the start button is push the relay clicks but ther is no voltage coming out of the red w/white stripe wire, possible bad relay? The opportunist that I am I tried to bypass the relay with a piece of wire, there went the electrical system fuse. The engine does turn over as I rotated it by hand thru the drive belt side cover. I tried hooking up a remote start (automotive style) & the starer just buzzed a little bit & wouldn't crank the motor over. Also I have seen an optional pull start for this 'wheeler. Any one have a used one for sale? Any help would be great, thanks. Wes
