2001 Recon idles high
Old Aug 29, 2005 | 11:59 AM
Pityocamptes's Avatar
Default 2001 Recon idles high
Hi, all. My father picked up a 2001 Recon for a good price this past weekend. We noticed that it idles fine on startup and then gradually starts to idle very fast (faster than normal). The guy brought the price down since he said it might need to have the varb cleaned. Appearently the quad sat for several months in storage. My father plans on draining and replacing the fluids and plug, etc. Could it be idling high from bad gas? the guy did not use any stabilizer. Any thoughts? Thanks.
Old Aug 29, 2005 | 12:11 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Have you tried just turning the idle screw down???
I had a batch of bad gas, and the symptoms were like the bike running lean, becasue of clogged jets.
Old Aug 29, 2005 | 12:34 PM
No, we haven't even got that far. He actually picks the bike up today. On what side is the carb idle screw (fuel select **** side or other side)? Also, he noticed a tube just hanging loose. Does the Recon have any sort of vacuum controls? I wonder if that line was a vac line and came off? Thanks again.
Old Aug 29, 2005 | 01:52 PM
hondabuster's Avatar
Depends on which tube is hanging down. If its the one on the bottom of the float bowl...then its normal, thats the vent/overflow.
Old Aug 30, 2005 | 05:01 AM
confusedbuyer's Avatar
IIRC, the idle screw is the only one you see from the side. I DEFINITELY recall scorching my hands and getting cramps trying to get at the f#@*&* air/fuel screw, which is recessed and at the underside (bottom) of the carb. there is a specialty screw driver for that one, or you can try a screwdriver bit, but it is rotten to adjust that one. i found removing the seat and adjusting it from thru/under at that angle worked best. Hinda spec was about 2 1/2 turns out.
Old Aug 30, 2005 | 12:06 PM
quicksilver's Avatar
i was messing with that mixture screw on mine, and it didnt seem to change the rpm much. I would adjust the idle speed thingy first. Go and warm the machine up with some normal riding, then adjust the screw (it actually has a twisty **** thing on it , just turn with fingers, it's on the right-hand side of the carb) Set it for about 1400 RPM, you will need a tachometer for precise adjustment. I bought one of those tiny-tach things from dennis kirk or JR Graham, it has a wire that you just wrap around your spark plug wire and a ground wire that goes to the frame somewhere, and it reads engine rpm. That way i can constantly monitor my rpm at idle
Old Aug 30, 2005 | 12:54 PM
OK. Last night we pulled the idle screw all the way out. Unscrewed the part that has the throttle cable running into the carb housing (sleeve, spring and needle assembly) and sprayed a very generous amount of carb cleaner in both orfices. Pulled the vac lines and sprayed carb cleaner in the vac assembly on the carb. assembled everything back and screwed the adjustment screw all the way in. Fired it up and it idled very high but probably because of the screw position. Turned the screw out a few turns and it purrs. Took it out for a ride and it works great! Must of had a passage blocked or something. Thanks again for the ideas and help.
Old Mar 2, 2016 | 08:48 PM
Letsgorodeo's Avatar
I have a 98 250 recon i bought off a friend. New carb new cdi new coil finally got it started and it idles way to high. I moved the screw and it didnt seem to do anything. Any suggestions??
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 03:10 AM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
