Need help on Blaster please!
Hey fellas,
What are the signs of a bad crank seal? I fired up the Blaster and it had a bad hesitation on the bottom end when I was revving it in nuetral. So then I held the throttle WOT to try and clear it out and after a few seconds it started pouring white smoke like Crazy! It harder to start now and still has no bottom end response, but blows WHITE SMOKE like crazy and stinks! Could this be the problem? If so how much $ to fix and do the cases need to be split? Thanks fellas!
I did a compression test. It has 145 lbs. So I don't think it's the head gasket, piston, or rings. I think it's some seal or gasket thats letting tranny fluid get up into the combustion chamber, just not sure.
