My banshee was acting wierd.
Old Aug 30, 2005 | 06:48 PM
fartman's Avatar
Default My banshee was acting wierd.
I went up to the local ohv and had then banshee in the back of the truck so I went for a ride and noticed the exhuast was not comming out of the pipes equally. I just put T5s on, the are not leaking , just not puffing the same. Also, with the t5s and a drop in k&n do you think racing gas is overkill? That stuff is expensive, but smells great.
Old Aug 30, 2005 | 07:09 PM
Rem's Avatar
Rem
did you rejet?????????????????
Old Aug 30, 2005 | 08:43 PM
blindside350's Avatar
Did you rejet? How many hours do you have on the top end? Are you plugs ok? Theres quite a few factors in this... just do a standard 2-stroke check up... And yes Race gas is excessive 91-93 octane will do fine. You could even run 89, the compression is pretty low.
Old Aug 31, 2005 | 01:26 PM
fartman's Avatar
I did not rejet yet, I wanted to take her out to see which way I needed to go. The plugs are new, don't know about the top end time. I am planning to do some modest engine mods, so do you think I should have the top end rebuilt as well?
Old Aug 31, 2005 | 02:15 PM
86LT250RFatty's Avatar
you might NEED to get a top-end since you didnt re-jet.. but you know that they each cylinder fires at different times, so both exhaust's pulse's wont be the same.... I would DEFFENATLY call up toomey and tell then your set-up and ask what jets they reccomend, then go from their. NEVER put pipes on a quad and intake and run it with out rejetting! no matter how long, you going to do damage.
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
hueby
Nov 6, 2015 11:34 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
essonlaker
Sep 10, 2015 01:12 PM
