drive clutch question
Old Aug 30, 2005 | 11:37 PM
colmc's Avatar
Default drive clutch question
I bought a used 2001 500ho and 3 weeks ago I had a bearing go on the drive clutch. I decided to take the clutch apart and replace the bearing. When I got the clutch apart I noticed several cracks staring at the base of the clutch working their way out. So I ordered a clutch thinking I didn't have the ebs (after comparing parts on the exploded parts list). I was wrong. I got the new clutch today and I noticed the difference. Can I still use the clutch? everything fits the same and it looks like it lines up with the driven clutch. Will it work or will I screw something up?
Old Aug 31, 2005 | 11:03 AM
Speedwerx's Avatar
You can run that clutch but you will no longer have ebs. You will also need to ge the belt off of a scrambler or sport a non ebs belt, you should be able to run the same spring and weights. Performance wise you will noitice more bottom end because with the non ebs primay you will be starting in a lower gear when it comes to the drive ratio.
Old Aug 31, 2005 | 03:25 PM
SPORTSMAN70003's Avatar
Hey Speedwerx I'm thinking of doing the same thing to my 700 by putting a 500 Scrambler primary on it. Can you tell me the difference in the belts Scrambler Vs. Sportsman ? Both look to measure 40 7/8" Thanks.
Old Sep 1, 2005 | 10:34 AM
Speedwerx's Avatar
The length and width are about the same the ebs belt is a little bit thick though. If you wanted I think you woul dbe able to run the ebs belt if you wanted but I thinkthe std. might be a little softer but I'm not sure. Just remember to check belt deflection once you put the none ebs primary on you will have to run a little but of slack in the belt compared to the ebs models.
Old Sep 1, 2005 | 01:06 PM
Thanks I just ordered a Non-ebs primary clutch and will try the ebs belt first.
Old Sep 1, 2005 | 01:26 PM
Speedwerx's Avatar
Sounds cool that thing should be really fun to ride now you will have a lot more bottom end and mid range power.
Old Sep 1, 2005 | 01:30 PM
Yea the thing is already a hoss and the Team roller I got from you made a big difference. I can't wait to test the non-ebs primary out.
Cole Hadden
Jun 15, 2025 09:05 AM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
D-Hagz
Jul 4, 2015 02:19 AM
