predator neutral override
Old Sep 2, 2005 | 12:28 AM
GITRDUN's Avatar
Default predator neutral override
Anyone know how to override the predators neutral only start.? Im getting it ready for my wife to race with friday and im afraid if she stalls it in a corner she will have a hard time getting it in neutral to start it. This things a B*t*h to get into neutral if your in a hurry. And being able to start in any gear would sure be nice.
I havent tore into the wiring on this thing yet so please be descriptive if you know the trick.
Old Sep 2, 2005 | 01:02 AM
predatordude2's Avatar
When the clutch is pulled in the switch at the clutch handle is push in to jump it. Did you remove the switch? I just did the Magura hydraulic clutch and it took a little time be get the switch to work.
Old Sep 2, 2005 | 02:02 AM
Webopper's Avatar
I must be missing something cause mine starts in any gear...from reverse on up.
Old Sep 2, 2005 | 09:34 AM
There are two ways of start. Put the engine in N light on, or pull in the clutch handle to tell the start relay that it is ok to pull in and start the motor, do to the clutch is pulled in. They have the switch in the clutch level do to you don't want the starter motor to crank.
Old Sep 2, 2005 | 10:08 AM
GITRDUN's Avatar
Well that sounds strange if everyone elses can start in any gear withc the clutch lever in. Maybe the switch on the clutch lever is not working and it doesnt know if the clutch is in or out. Ill have to check it out.
Old Sep 2, 2005 | 01:28 PM
zilla24's Avatar
While we are on the subject of predator starting, does anyone know of a way that you can roll start a predator? I imagine you have to disable some switch or something like that, anyone do this on theirs? It would be nice to roll start it if you stalled out on a hill or if your battery died out on the trail.
Old Sep 2, 2005 | 03:22 PM
GITRDUN's Avatar
Ok i feel smart as a rock. I hit the starter with it in first gear and clutch in and it rolled over fine. I know ive tried to start that thing before and it wouldnt roll over if it wasnt in neutral.
Old Sep 2, 2005 | 05:41 PM
there is a plug just under the handle bars. just pull on the wire or look under the plastic to see it. make sure it is plug in.
Old Sep 2, 2005 | 07:42 PM
Webopper's Avatar
LOL...we've all been there, some of us more than most...[img]i/expressions/face-icon-small-confused.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Dammar
Apr 20, 2016 06:03 AM
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
