stupid question
What year is your Xplorer? If it is a pre-concentric drive(1998 and before) when taking off the strap it should have some play, but not too much.
If I remember right, when I do my rear chain there is about that much play but after the strap is removed.
It is normal to be loose. If this bothers you, the best thing to do is get a spring loaded tensioner. Believe me, you are better off running too much slack as opposed to too little. Something can get between the chain & sprocket & if there isn't enough slack, something has to give. Usually it is the chain, but occasionally I have heard of a ruined bearing in the transmition and even a cracked case or two.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
