stupid question
Old Oct 23, 2000 | 12:08 AM
cajins's Avatar
on my 400 explorer after i adjust my chain and remove my strap the chain has a ton of play in it. is this normal? when the stap is on it is about a half an inch of play.
Old Oct 23, 2000 | 12:17 AM
Xplor's Avatar
What year is your Xplorer? If it is a pre-concentric drive(1998 and before) when taking off the strap it should have some play, but not too much.
If I remember right, when I do my rear chain there is about that much play but after the strap is removed.
Old Oct 23, 2000 | 04:29 AM
AKScrambler's Avatar
I tighten mine with out a strap. I make sure it has about 3/4" of play as it sits. I've never had chain problems at this setting. I have a pre-concentric drive.
Old Oct 23, 2000 | 09:09 AM
Farmr123's Avatar
It is normal to be loose. If this bothers you, the best thing to do is get a spring loaded tensioner. Believe me, you are better off running too much slack as opposed to too little. Something can get between the chain & sprocket & if there isn't enough slack, something has to give. Usually it is the chain, but occasionally I have heard of a ruined bearing in the transmition and even a cracked case or two.
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
