99 scrambler pulls to right???
Old Sep 10, 2005 | 02:05 PM
marksduramax's Avatar
Default 99 scrambler pulls to right???
when i have it in 4 wheel drive it wants to pull to the right some but dose it bad when you take it out of 4 wheel drive what could it be?
Old Sep 10, 2005 | 06:07 PM
cornbread2's Avatar
Two things can cause this. One locking hub is staying in or one rear tire is taller than the other.
Old Sep 10, 2005 | 07:00 PM
XtremeSkier's Avatar
mine does that to, i generally just take it out of 4 wheel drive and wait for it to stop, then try it again
Old Sep 11, 2005 | 12:15 AM
jimk72's Avatar
Drain both front hubs and then refill with polaris hub fluid. Don't fill them all the way up, turn the tire so the hole is at like 2 o'clock and then fill it till it gets to the hole. This usualy fixes it. I usualy change my hub fluid every summer.
Old Sep 11, 2005 | 12:23 AM
whats a trick to get a striped head out the allen head it striped out on the left side
Old Sep 11, 2005 | 12:37 AM
jimk72's Avatar
Remove the end cap and make sure there is nothing right there that will get hit and drill it out. Find out what size the hex screw is and redrill and tap it. I seems like a pain but it is really easy. You just need the right size bit and tap and a new screw. Once you get that should only take a few minutes.
mitchxc700
Aug 10, 2015 09:26 PM
1000gade
Aug 9, 2015 03:34 PM
raceware
Jul 30, 2015 06:59 AM
DeFox500
Jul 26, 2015 06:32 PM
maxjung
Jul 13, 2015 05:11 PM
