help!!!
Old Sep 11, 2005 | 10:48 AM
ihop's Avatar
Default help!!!
ok i was driving down a hill on an alpha sport summit 180 friends and he told me to put in in netrul down the hill when i did it went into reverse i quickly put it into netrul and brake i came to a stop and pressed the gas and did not moved got off looked down and my drive sproket was not there what do i do can i order a new one for him the chain only missing a link from when we towed it so he can fix that im so mad at my self please help fast thanks
Old Sep 11, 2005 | 11:27 AM
spike99's Avatar
Default help!!!
Based on the tone, I can tell you're in "Panic Mode". To order a sprocket for this ATV, try:
- Local Alpha dealers. Hopefully, you have an Alpha sport dealer in your yellow pages / phone directory.
- Rebel Gears. Their URL is: http://www.rebelgears.com/pages/787900/index.htm
Notes:
1 - Inspect both sprockets, chain and chain tensioner / guides (if it has one). If these are damaged or worn, you may want to replace them as the same time. Also need to fully test the F & R gears before hitting those long trails. Want to ensure there's NO internal tranny damage before driving into the remote locations.
2 - When driving down a hill, NEVER put it in "N". Even if your engine doesn't have engine breaking, putting in "N" is a very bad thing to do when going down hills. Since he told you to do it, wonder if he should pay for some (or all) of the damage??? Your call.
Hope this helps....
Old Sep 11, 2005 | 11:28 AM
LT80's Avatar
LT80 Expert
Default help!!!
If the sprocket simply fell off, then yes you just order another.
I'm curious as to whether the shaft that the sprocket goes on stripped/broke. Check that out first.
Did it hit hard in reverse? Any noise (clang/bang/boom) when it hit reverse?
BTW:: the recommendation to put it in neutral was a poor one, but I guess you and he knows that now. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 11, 2005 | 11:32 AM
ihop's Avatar
Default help!!!
it is strip no sporekt just metal worn and it did just go clang for like 3 seconds the i put it in neutrl then stop and and would not go im paying for it becuse hes not very wealth person and i work alll summer and i have the money and i was riding it so i will pay for it
Old Sep 11, 2005 | 11:35 AM
ihop's Avatar
Default help!!!
yea i need the shaft and sporket found one for 80 dollars on an alpha sport website is this good
