some body help, i have no spark
Old Sep 11, 2005 | 07:17 PM
soadrocksever's Avatar
Default some body help, i have no spark
yeah, my key for my atc 200es was lost so i had to cut the ignition wires and hot wire it.... through the process of touching the yellow and red wire it turns the ignition on. and now i dont have any spark going to the spark plug... i put a test light on the spark plug wire and it still didnt show ne thing. can someone pleae help, im lost w/o my three wheeler
Old Sep 12, 2005 | 11:56 PM
xljimmy's Avatar
If nothing got fried ,reconnect the wires. I know for sure that polaris trailblazers and my 400ex will run with the ignition switch disconnected. The 400ex has to be push started. Just unplug the switch. I bet yours is the same way. Most ignition switches just ground the coil out so when the switch is off it is grounded. With switch unhooked the coil isnt grounded and should run. I am not familar with the 200es but if it has electric start the starter wont work. Also I am not sure if the charging system would work. If it is non electric it will run forever like that. If it is just check the charging and if it isnt make sure the battery dont go dead out in the middle of nowhere cuz you will lose spark. I had to do that when my now ex wife took my key for the 400ex. I didnt ride it long but had no problems once I got it push started.
Old Sep 12, 2005 | 11:59 PM
i hear people say disconnect the ignition... where and how? i tried but maby im not doing it right
Old Sep 13, 2005 | 12:09 AM
xljimmy's Avatar
The 400ex was right behind the switch. It was a pain to get to without removing anything but it I did get it. It might connect at the switch or might have a liittle pig tail. Someone with knowledge of the 200es will have to help further. Good luck.
Old Mar 10, 2010 | 03:53 AM
drjoe171's Avatar
Default 200es spark
Mine did the exact same thing. Got spark with the pullrope Put a battery in it and it lights up and spins but NO spark! so tomorrow, I'll disco the battery and got backwards and see if I got spark again. I have seen it where the lights or horn will try to come on when trying to start so the ignition circuit is trying to share some grounding path. Gonna hafta clean everything with a ground. it has no ignition switch, just 4 wires hanging out. the little ones kill it and the other 2 make the neutral light come on but NONE of them need to be connected at all to run it. They are just there for the electric start and kill circuit. dont forget to check your fuses ALTHO they really have nothing to do with with the run circuit
fordfaithful21
Dec 7, 2015 05:52 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
donintennessee
Aug 19, 2015 02:22 PM
