Jetting and Premix
Old Sep 15, 2005 | 09:00 PM
wildbillbud's Avatar
Default Jetting and Premix
I have a scrambler 400 4x4 and premix now. Do I need to rejet the carb? The machine is still stock everything.
Old Sep 15, 2005 | 09:02 PM
Sorry this scramber is a 2002 and has a main jet of 240, pilot jet 25, air screw 1.25.
Old Sep 15, 2005 | 09:13 PM
Kahnman's Avatar
You will not have to rejet. Mix synthetic oil 32:1 for initial break in. 40:1 rest of time. If you choose Amsoil Saber 100:1 prmix, you can easily run 50:1 wit no problem. I run that on my race mod and no problems. HPD runs 66:1 on the race mods too. You should "WFO" every once in a while to clean out the plug to prevent premature fouling. Good luck.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 15, 2005 | 09:33 PM
duneaholic's Avatar
I run Amsoil injector oil and premix at 50:1 at all times for over 2 years now without a single problem. GO AMSOIL!
Old Sep 16, 2005 | 01:49 AM
I have already premixed 2 gallons of gas at 40:1 will Polaris blue. Is this is an alright mixture? Tommorro I will receive my oil injector block off kit and single throttle cable. When I install everything is there any hints you can give that you learned from experience? Thank you Kahnman for the jetting answer. By the way I had a previous post that no one responded to that explained why am doing this. Heres the link: My Original Thread
Old Sep 16, 2005 | 02:19 AM
duneaholic's Avatar
I think most people that run the Polaris blue run a ratio of 32:1 so you may need to up the oil a little. One hint I can tell you about installing the block-off plate is to make sure you get a good high temp silicone sealer to seal it up. If you don't it will leak out oil from the crankcase. I know from experience. On the cable just be sure you route the cable good and don't get it in a bind and make sure you adjust the cable so the slide will travel the entire lenght of the throttle range.
I responded to your other post as well.
Old Sep 16, 2005 | 02:20 AM
DemonDS's Avatar
I can see alot of advantages with this setup. Lose the extra weight of oil that isnt being used pluss all the stuff involved with it. Mixing is a pian but it is better to mix than risk the oil pump going out and you not get any oil. Very much so on the big $$$ high strung motors.
Old Sep 16, 2005 | 04:42 AM
Thanks for all the help. Ill take your advice duneaholic and use a good sealer on the plate.
Old Sep 16, 2005 | 12:43 PM
conig's Avatar
get the single throttle cable. the dueal one will work at first and then most likly stick. plus it reacts slow.
mine stuck in my town house yard(big for a town house but no more then a quarter acre) and sent my quad sailing into my privacy fence just fyi, I wish someone had a camera it had to of been funny as all hell. The MSO bumper is pretty tough.
Old Sep 16, 2005 | 04:26 PM
What the?!! I received my block off kit and single throttle cable today from HPD and there is no plug in the kit. I thought there was supposed to be a plug to stick into the hole the injector pump gear came out of and then I cover it up with the plate?
