rubicon shift question
Old Sep 19, 2005 | 12:05 AM
yarddawg's Avatar
Default rubicon shift question
new here and looking for some advice. i have a 2000 rubicon. it is haveing shifting problems. will not shift in the auto or the electirc mode. also when i go in reverse it will miss. the disply on the speedo has the d1 d2 el shift emblems blinking. i'm thinking it may be the shift senor, if so where do i find it and how do i check it see if it is the problem. also is it hard to cahnge. any info is greatly thankful here...................dawg
Old Sep 19, 2005 | 10:42 AM
TIC's Avatar
TIC
do a search onthis site for reset procedure on rubicon.
or goto google and do a tex mudders honda rubicon search, he has the reset procedure on his site too.
Iv had to do it twice on mine in 3 years. worked everytime and nev er cost me a dime.
Old Sep 19, 2005 | 11:00 AM
TIC's Avatar
TIC
http://www.ansley.net
youll have to look under service tips, then goto reset procedure. He also has service codes and how to get them. It will tell you exactly what is wrong,, buy the number of flashes.
chances are this reset will work though.
Old Sep 20, 2005 | 07:18 PM
yarddawg's Avatar
tryed the reset but no luck,any ideas what is going on here, the first time this happened
Old Sep 21, 2005 | 11:50 AM
HMRUBICON's Avatar
My 2001 Rubicon did this once and i checked the fuses, none were blown, but some had corrosion on them, like a white chalky substance, so i cleaned the fuses and it has worked fine since. Might not be your problem but you never know.
Old Sep 21, 2005 | 11:57 AM
TIC's Avatar
TIC
any chance you did the "retrieve" service codes? did it give you a number of flashes?
after you have done this you may try the total disconect of the battery and let sit for a while.
and yes checking all electric connections for water is a great start.
Did you pressure wash this thing or have it sunk inwater previous to your problems?
How is your oil level.
When you did the reset did you hear the angle motor moving? should sound like a click and then a small motor hummmm then a click.
did you roll the quad so far during the reset like it stated?
Old Sep 21, 2005 | 10:43 PM
yarddawg's Avatar
got it. it was the fuses, had all kind of white powder on them and the fuse block. cleaned it real good. and it works fine, thanks for all the info here........dawg
Njrider1230
Jul 29, 2023 05:16 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Kodiak-vic
Jul 29, 2015 03:06 AM
