More Electrical
Old Sep 20, 2005 | 11:41 PM
HarryinPA's Avatar
Default More Electrical
i spent some time under the hood this weekend and I pulled the single wire from the ACC fuse terminal and
hooked up a light I am using for testing. It powered the light whether the ignition was on or off. I was hoping
that the lights and accessories I am hooking up would not be hot when the ignition is off even though they will be
switched beyond the fuse block. Isn't there a post ignition place to hit this wire?
Also I still can not find the extra accessory plug that the manual says exists on this quad. Its supposed to be back by
the wiring harness and I looked everywhere removing plastic panels as necessary to hunt for this plug.
Does anyone know where it is? [img]i/expressions/face-icon-small-confused.gif[/img]
Thanks,
Harry
Old Sep 21, 2005 | 03:10 AM
Bear4570's Avatar
I can send you an electrical wiring diagram if you like.
Old Sep 21, 2005 | 09:21 AM
HarryinPA's Avatar
Bear,
If you mean the standard AC diagram, the one that's available on Alpha Sport's site I have that already. It generalizes the main harness because
it is a single part number and does not show the details. If you have something else I would welcome it. Remember that the 250 has a slightly different harness
for some reason and the extra acc connector is on the front of that quad according to my manual.
Harry
Old Sep 21, 2005 | 01:17 PM
Bear4570's Avatar
No, I mean the one from the service manual that shows where the wire go individually, the real thing.
Old Sep 21, 2005 | 09:57 PM
HarryinPA's Avatar
Bear,
Thanks, that would be great. If that turns out to be a different manual than the dealer had I need to get one.
Harry
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
