vavles
Old Sep 26, 2005 | 08:33 PM
RideRedOrStayHome's Avatar
Default vavles
would improper vavle adjustment cause an engine to burn oil or what else cold cause it to burn it
Old Sep 27, 2005 | 10:34 AM
ddrumman2004's Avatar
Default vavles
Do you have a compression checker? If so, check the compression. Then pour an ounce of oil in the cylinder and check again. If the compression comes up...it's the rings. If no change...it's the valve stem seals. Be sure engine is warm when you do this.
bama400ex
May 10, 2004 08:47 PM
mwllwm
Apr 18, 2003 04:24 PM
TRX250EXER
Jun 24, 2002 08:15 PM
