newbie questions
Old Oct 2, 2005 | 10:46 PM
305400ex's Avatar
Default newbie questions
Hey guys I just bought a 2001 400ex with a busted rear axle carrier. I ordered a rad tapered carrier for it (friends advice). I just finished doing a tune-up on it, but have a question. Do i need to gap the spark plug before installing it? The bike is stock except for a yoshimura pipe (P.S. im not the most mechanically inclined person sorry if its a stupid question.)
Also what would be some ideal maintenance tips that I should do. I ordered the manual but it has not yet arrived. Thanks in advance, and any advice is greatly appreciated.
Thanks,
Idal
Miami, Fl.
Old Oct 2, 2005 | 11:06 PM
305400ex's Avatar
actually I found the gapping size on the the webiste ngksparkplugs.com. I would still appreciate if you guys could give me some maintenance tips.
Old Oct 2, 2005 | 11:08 PM
TractorPacker's Avatar
Do you have a balloon?
Keep up on the opil changes, and keep the airfilter clean. The 400ex is a reliable quad, so you should be fine.
Old Oct 2, 2005 | 11:09 PM
Torbinx's Avatar
No you dont have to gap the spark plug it should be good if its a brand new plug and if its an old one you can just clean it off with a wire brush and check the gap to be sure. As for maintanence tips lube your chain every couple rides, check air pressure every 1-2months, check air filter for cleanliness every couple months and if you ride in mud its alot easier to wash it off if you spray it down the day of your ride cause the longer you wait the harder you gotta scrub. You can also tell if your front shocks are shot when oil leaks out and runs down the shock and it will collect a fair amount of dirt and such and not come clean so easily.
Hack714
Oct 6, 2015 06:51 AM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
that1redhead
Sep 8, 2015 11:47 AM
