Problems with a Billet Thumb Throttle
Old Oct 4, 2005 | 07:41 AM
cpaul's Avatar
Default Problems with a Billet Thumb Throttle
I installed a billet thumb throttle (extended) Bought it off someone on the forum, came with the spacer which I am sure goes between thethumb throttle and housing. Tightened the bolt.
If I just push on the throttle normally, everything seems fine, but if I grab the bottom of the thumb throttle, I can move it back and forth with my hand.
Does not seem right that it would move??
Do I add washers??
Any ideas?
Old Oct 4, 2005 | 10:53 AM
busmechanic's Avatar
I was thinking the one I had was a machine fit. are you sure the housing is not hogged out?
Old Oct 4, 2005 | 01:46 PM
OregonDunePatrol's Avatar
You havent mounted it correctly. The square shaped pin must match the throttle arm. You currently dont have the squares lined up.
Old Oct 4, 2005 | 06:05 PM
cpaul's Avatar
Thanks ODP, I will try to correct tonight.
Old Oct 4, 2005 | 08:12 PM
ILivSD's Avatar
Hi cpaul,
I also purchased one of those extended levers.
I don't know if I installed it correctly but the actuation worked great but the positioning of the lever was all wrong.
It killed my wrist as I could not grip the bar correctly. I ended up putting the stock one back on.
Maybe I will try it again I hear you have to move the whole actuating lever over to get the right location ?
Any one else know if this is correct ?
Old Oct 5, 2005 | 07:46 AM
cpaul's Avatar
That is interesting, I have heard nothing about the actuating lever, left mine the same.
I worked on this thing for almost an hour last night. Must have re-installed it 15 times! Still has some play if you grab billet thumb piece and rock it back and forth. May be wollered out a bit?
Don't notice it when you are just "on the throttle" will try it and keep the OEM one just in case.
Thanks for everyone's help!
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
