keeping my 400 ex cool??
Old Oct 11, 2005 | 12:38 AM
rooinater's Avatar
Default keeping my 400 ex cool??
i was up at cinder hills in arizona a month or so ago and the engine was getting extremely hot. i have a 2005 400ex, it has a stock oil cooler. but i was wondering if anyone had info on a larger oil cooler or some ideas on how to keep the engine cooler?
thanks,
Jared
Old Oct 11, 2005 | 01:49 AM
Torbinx's Avatar
i think you can get some omf or similiar scoops.
Old Oct 11, 2005 | 10:01 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Did you rejet for the higher altitude at Cinders??? If you got it to lean, that might contribute to the problem.
Being air cooled, there isn't a whole lot you can do.
Old Oct 11, 2005 | 02:17 PM
droz's Avatar
air scoops
i think they make a bigger cooler...might have to adapt one though if not
bigger oil tank
Old Oct 11, 2005 | 02:20 PM
Hondanutcase's Avatar
There are some after market oil coolers out there, but to be honest I don't know that it would make much difference. However for a 400ex it is crucial to have it jetted properly. I always run mine just a little rich. Also on those hot days (even for liquid cooled machines) keep it moving. The air going over the engine is very important. Shrouds may help a little, but again only when the machine is moving.
Old Oct 11, 2005 | 03:04 PM
Trxoutlawz's Avatar
Scoops will help.. Also,, you may want to put on an auxilary oil cooler..
Old Oct 12, 2005 | 12:42 AM
claas900's Avatar
..larger oil cooler..Call micky at FST,he offers on..or if you know what to do you can make your own..Extra oil helps a lot on an EX..
Old Oct 12, 2005 | 02:48 AM
number8redrider's Avatar
I'm not sure - but I think i've seen coolers w/ a fan attatched ??? - and I know someone makes bigger coolers - I use a pingreys brand oversized oil tank on mine - it holds an extra quart or so - the nice thing about the one they make is it has like 7-8 one inch tubes thru it from front to back - to increase surface size and the air can flow thru it - - with that and air shrouds and keeping my cooler clean (if they're clogged w/ dirt they don't work) mine hasn't overheated yet and it's FAR from stock - -good luck
Old Oct 12, 2005 | 07:58 AM
rooinater's Avatar
does anyone have a way to get ahold of mickey at fst? i've been trying to find anything on four stoke tech. but can't get anything to actually find a way to contact them.
as for rejetting. from the pheonix area. how many jets up or down in size should i go. i beleive the pheonix area is around 1000 feet. and cinders is about 7 to 8 thousand feet..
so scoops, rejetting, and find a way to get ahold of mickey for a possibly larger oil cooler?
thank you guys
jared
mtdewmn
Jan 19, 2017 12:13 PM
gamer17
Aug 15, 2015 12:38 PM
clsharky
Jul 13, 2015 02:07 PM
