Cant keep up with a Z400
Old Oct 13, 2005 | 03:02 PM
DSlider's Avatar
Default Cant keep up with a Z400
Hello. I recently upgraded my 2004 DSX with a QRS slip on muffler from HMF. I also have a UNI filter.
I run with the lid on. I started jetting with 175 main, but it didnt like it (too rich), went down to 170 and it felt right.
The problem is, after this mods, my quad cant beat a stock z400 on a 300ft race. It stays preety much with it until the very last moment. We switched quads with same results. Is this right? Or do I have a problem
I have 22 Razr with stock gearing.
I dont do drags, I do mostly desert racing and some motocross, but am concerned that I am not getting the maximum from this mods.
Any suggestions?
BTW, the QRS is a very quiet pipe, which HMF states it only looses 10% ovarall compared to the sport series.
Thanks
Old Oct 13, 2005 | 03:11 PM
FatHolly's Avatar
What is the weight difference between you and the other rider? I am 330 on a DS and my friend is maybe 200 on a Z400, and I can get him by a couple lengths in 300 feet. I run the HMF sport, and can't comment on the QRS, but it seems to me that you should be able to take your friend easily. I wish I had an answer, but maybe try checking your plugs to really know if your jetting is on. Good luck.
Old Oct 13, 2005 | 03:17 PM
ILivSD's Avatar
Hey DSlider,
I know what you mean... I did a bunch of mods to my bike and I was just able to keep things neck and neck on a race with a YFZ450 as I my DS was way out of tune.
I caved in and had the bike Dyno tuned and gaind like 6 horse to the rear wheels you could see the power was dropping where it should have been strong then pick back up again ....
Now I am ready to RUN with the Big Dogs...
Proper tuning makes all the difference in the world ... enought to pay for it I guesssssss
[img]i/expressions/face-icon-small-smile.gif[/img]
Coyoteman's Avatar
With 22 inch rears try gearing down to a 14 tooth front sprocket, it will help considerably.
Old Oct 13, 2005 | 04:13 PM
DSlider's Avatar
ILivSD, how was your jetting after the dyno tune? Did you mod the carb (vacuum holes?). Are you running with the air lid on?
I weight 200lb, and my friend 150lb. But the thing is, when we switched quads, the result was the same.
I feel the engine takes too long to rev. I does get there, and feels strong, but it takes a while to hit the rev limiter.
Old Oct 13, 2005 | 04:20 PM
Camds650's Avatar
I had the same probem and it ended up being the carb slide.
look here
Old Oct 13, 2005 | 05:23 PM
Bone1208's Avatar
You must have some sort of problem. My neighbor has a Z400 and i usually take him by around 3 to 5 lenghts by the time i shift to 5th. He weighs around 180 and im around 300.
Old Oct 13, 2005 | 05:25 PM
lilnotts's Avatar
order a 14t and 15t front sprockets from RMATV, cheap, like 15 a pop, and try them both to see which you like better, right now your gearing is too tall
Old Oct 13, 2005 | 06:33 PM
DSengineer's Avatar
Has been here a long time!
As others have mentioned you should gear down to compensate for the 22's however even with stock gearing you should be mopping up the Z. I would say you have a tuning problem of some sort. Where is your needle set?
Old Oct 13, 2005 | 06:40 PM
DSlider's Avatar
Here are my specs:
Needle in 4th position
Main Jet 170
Air lid, on
Uni Filter
Muffler: HMF QRS
Everything else stock
Alltitude: 3000ft
Temp: 90F
Also, just read Oldman's stock carb reccomendations, and am doing them tonight.
Thanks
