How the hell do you raise the shifter??
Old Oct 28, 2000 | 12:27 AM
WIDEOPENCLUB's Avatar
Just got some boots and can't get the shifter to raise up.....something special you have to do to get the shifter off the shaft????
Old Oct 28, 2000 | 12:29 AM
Oh I guess you need to know the bike....its a raptor
Old Oct 28, 2000 | 12:54 AM
paulb's Avatar
Hi
you will have to replace the adjuster with a longer one.
paul
Old Oct 28, 2000 | 01:03 AM
How do you get it off the shaft though?
Old Oct 28, 2000 | 01:28 AM
Joey9's Avatar
Use the adjuster. You don't have to pull the shifter off the shaft. Just loosen the 2 nuts for the linkage and turn the middle piece then re-tighten the lock nuts. If you need more space then that just bend the lever a little bit or get a longer adj. screw. Later
Old Oct 28, 2000 | 01:33 AM
Wow didn't think of that......maybe thats why they call it an adjuster...hmmm....too used to the tecate and 400ex....always had to take off the shifter....anyways thanks for the help
Jon
Old Oct 28, 2000 | 01:36 AM
By the way how do you like the CS ign. advance and how hard was it to put on,,,,Do you have a flywheel puller that fits?
Old Oct 28, 2000 | 01:38 AM
paulb's Avatar
you dont take the shifter off. the link between the shifter and the shifter shaft is the adjuster.
you have to undo the lock nuts on both sides (the one is right hand thread and the other is left hand thread ) and unscrew the adjuster. the standerd adjuster is to short to compensate for the amount of lift you need for riding boots.
paul
95wolv
Sep 27, 2024 12:00 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
