04 400 manuel shift
Old Oct 24, 2005 | 03:17 PM
wall2048's Avatar
Default 04 400 manuel shift
trans is sticking every now and then have to trun engine off then pull up hard on shifter to unstick then will do fine for awhile. any suggestions?
Old Oct 24, 2005 | 03:51 PM
ArcticBrat's Avatar
If your engine is idleing to high it will be hard to shift...Might need clutch adjusted...I had an 04 400 manual shift arctic-cat and at 700 miles I had to replace the clutch (warranty covered it) When I sold it there was 2400miles and no problem's with the clutch...Does your quad still have any warranty left...When mine was in the shop getting fixed there was another 04 400 a-cat haveing clutch replaced so there must of been a few bad one's....
Old Oct 30, 2005 | 07:24 AM
Nats's Avatar
I had same issue with my 05 400 4x4 man. The idle was to high....adjust and you will be fine. Not sure how to? take to dealer and they will do it in less them 5 minutes time.
Old Oct 30, 2005 | 10:07 PM
Bear4570's Avatar
Could also need a clutch adjustment if the lowering the idle doesn't cure it..
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
