Raptor jetting issues
Old Oct 26, 2005 | 03:03 PM
CrashLL's Avatar
Default Raptor jetting issues
I have jetted my Raptor with HMF full pipe and K&N pro flow. I used DJ's 148/146 3 turns out on screw and 4th clip from the top on the needles. Anyway, It is running to rich at idle, unless I keep the choke open about half way. Then it runs awesome. Do I just need to move the clips on the needle up, Or do I need to run leaner jets? Any help would be great. It's time to go riding and I need to get her done! LOL
Old Oct 26, 2005 | 04:54 PM
warwgn's Avatar
try 2 1/2 turns out on A/F screws and put the clips on the 3rd clip from the top and see how close that gets you.
Old Oct 26, 2005 | 05:35 PM
CrashLL's Avatar
I'll give that a try. I just want to get it running right, without pulling the carb out too many times. Thanks!
Old Oct 26, 2005 | 05:58 PM
warwgn's Avatar
with a raptor you better get used to pulling the carbs out, each bike is different and it takes several tries and combos to get the jetting right, and on top of that you should change jets between winter and summer.
Old Oct 26, 2005 | 06:10 PM
CrashLL's Avatar
I don't have to worry about riding in the summer here, It's too damn hot!!! LOL But yes, I have already had it apart a lot, so it's not a big deal. I'm just having a hell of a time getting it jetted right this time.
Old Oct 26, 2005 | 06:20 PM
Ozark38's Avatar
You obviously are running with the lid, correct? I had the same thing and it ran great at 2 3/4 L and 3 R but I had no lid. I would try 2 3/4 on both. I probably wouldn't move the needles cause you're already running small jets.
Did you remove the half flaps inside the snorkle?
Old Oct 26, 2005 | 07:29 PM
CrashLL's Avatar
Yes the flaps in the snorkle are removed. I guess I just need to tweek it here and there until I get it right.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
