Helping buddy jet his warrior what should I start at
Man do not just started thowing jets into a carb. take the plug out you want to plug to be a light brown. If the plug is black or even wet and black you are rich you need to go smaller on the jet. If the plug is white you are lean you need to jet it up. do not run the warrior lean you will burn a hole in the pistion.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
