trail tech torch light
Had these put on my handlebars and when I went to buttercup this weekend they really worked well. Lit up everything except when I parked to view the races up the hill I turned everything off, but when I tried to start my pred it just would not start except with a start. When I just used the pred lights everything was ok only problem was when I turned on the torch lights. Anyone have this problem in the past? Thanks.
well not to sure what you mean by "with a start" assuming it wouldn't start with the lights on? I installed 2 pair of equivalent ebay POS's that use the same bulb on my Raptor 660, it would run fine with all 4 on but would die at idle with both pair and definatly wouldn't start with either pair on. I think they just pull to much wattage to get a good spark at idle or starting. I broke all 4 lights I had, got some Trail techs on order. I would bet that your battery isn't as fresh as it should be and your just asking to much from your stator powering those lights. Thats what happened to me.
bzdok1234
30
Feb 23, 2016 01:55 PM
