New warrior sprokets
Going to order new sprockets and a chain for my warrior, so my question is what combination do you recommend. Stock is 13 front 40 rear and im wanting to bump up the low end power some. I hear alot of people go to 12 on front because its cheaper to replace but since im changing both front and rear not sure if would be better at a different ratio thx [img]i/expressions/face-icon-small-smile.gif[/img]
Well its whatever you like. If im in the sand with paddles on i use a 13 front and 44 on the back and if im fixing to race on the round track or just go play i use a 16 front and the 44 on back or i mite put a 42 on just depends.what the 16 on front and the 44 on back does is makes the gears longer and you know on a warrior the gears are real close together. hope that helps
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
