need some help fast on a rubicon electrcal problem
Old Nov 4, 2005 | 09:36 PM
yarddawg's Avatar
Default need some help fast on a rubicon electrcal problem
ok guys need some fast help here if you can help. i have a 2000 rubicon, it has been sitting up for a mounth or so. tried to crack it to go riding in the morning and bam, no juice. i charge the battery,even had it checked. they told me it was good. even change some fuses. it will not even blink! when i first tired to crank it, the display would come on but it woulod not turn over, finaly the display would not even come on. I need some quick help here on any suggestions on where to start. ..............thanks dawg
Old Nov 4, 2005 | 10:02 PM
ford8n47's Avatar
Not sure if you could drift start the thing in gear...I know somewhere in this forum tells you how to do it. If everything comes on then when you crank it, it dies then the battery is bad. I'd start with a new battery even though you had it tested...try a new one, you can always take it back. If it still does it then you might have a ground somewhere. I'm no electrician but there is something sucking the juice. Make shure all things are off before starting. Give a little more info on the gears, and any other features of the machine...new winch installed etc. Not sure if that will help. But it sounds like a bad battery. I had them register good and fully charged on my charger only to die on start up.
Old Nov 4, 2005 | 10:29 PM
yarddawg's Avatar
nothing new has been added to the bike. it is very puzzling. it will not show any thing on the display at all, nothibng is working.
Old Nov 4, 2005 | 11:54 PM
yarddawg's Avatar
got it fixed, it was a loose fuse. the fuse was not blown just had some type of lose connection inside the fuse casing. it was the headlight fuse also............if any of you have this type of problem in the furture, hope this helps........later dawf
Ramman1
Jun 16, 2016 09:07 PM
JackTheKing
Jul 14, 2015 09:09 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
Jul 7, 2015 11:00 PM
