where to source yamoto transmission spares ???
Old Nov 5, 2005 | 09:30 AM
hollowman's Avatar
Default where to source yamoto transmission spares ???
i have found that the 2nd gear slector fork and gears are badly worn on a quad less than 6 months old
resulting in the quad not engaging 2nd gear
but there is no where that these parts can be sourced i have emailed the manufactures to no success
all i know is the engine is a copy of the honda cg125 ohv but in a bigger 200cc scale
im not even sure if the cg125 internals would fit but doubt it as the engines are modified to have reverse
Old Nov 29, 2005 | 04:26 PM
shmily's Avatar
i don't know if you have found parts yet, but if you do let me know. I have an Akuma 150cc, and have contacted manufacture, but no response.
Old Nov 29, 2005 | 04:42 PM
hollowman's Avatar
hi i managed to find the parts i need by mixing and matching
the gearbox parts i used were out of a honda cg125 and are nearly a direct replacement
and i also needed a ball joint for one of the A arms this was sourced from a gas gas quad
at least i know that ther gearbox wont fail again as i swapped out the parts with the original honda spares from the cg 125
just means swapping the coresponding gears on the other shaft
Old Mar 5, 2006 | 07:16 PM
Guest
Guest
Posts: n/a
do you got a number or website for the manafacture?
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
kbazzy
Sep 26, 2015 11:26 AM
WilliamBos
Sep 22, 2015 04:07 PM
