LT 80 Wont Start
Old Nov 5, 2005 | 04:58 PM
kent's Avatar
Default LT 80 Wont Start
My son ran his LT 80 until it ran out of gas. I filled it back up and it would not start, but would backfire occasionally. I put a new plug in and cleaned the carb and it still wont start. I took the plug out and it was dry. I took the reed cage out and everything looked ok. I put another carb on and still nothing and the plug is still dry. Anyone know where I should look next. The gas is getting to the carb, but nowhere else.
Old Nov 5, 2005 | 05:13 PM
defcon5's Avatar
You might have had some sediment in the tank from running it dry. You might want to check the lines.
Roman
Old Nov 6, 2005 | 11:41 AM
LT80's Avatar
LT80 Expert
Remove the air filter boot from the carb. Use 2 fingers to hand choke it. [img]i/expressions/face-icon-small-wink.gif[/img]
I bet it'll start. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 6, 2005 | 02:04 PM
kent's Avatar
I took the air filter off and tried that and all it did was backfire. Ive ruled out everything from the fuel lines to the carb to the reed cage. Is it possible I have problem with a head or base gasket.
Old Nov 6, 2005 | 07:13 PM
LT80's Avatar
LT80 Expert
So the plug is wet now?
Possibly a gasket roblem. I'm leaning toward compression. Better do a compression check.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
