need carb help big red
Old Nov 6, 2005 | 09:44 PM
neversunk's Avatar
Default need carb help big red
I got a rebuild kit for the carb on my 84 big red ATC 200E...and have an small o-ring leftover. I found no o-rings of that size in the carb (like maybe 3/16 O.D. approx), and the drawings in the clymer book and the ones posted here on the site are too rough to read where the darn thing goes. Can anybody explain its location to me in simple terms? The machine runs fine, but the idle does'nt sound right and won't stay consistant .....especially if you want it to idle low. I assume it has something to do with that.. Thanks....
Old Nov 7, 2005 | 03:47 PM
barrister1's Avatar
I believe there are two (2) little black o-rings on that carb. One goes on the air/fuel mixture screw on the bottom of the carb. The other goes on the idle adjust screw on the side of the carb. If you're not sure which parts I'm describing, you can do a search on this forum for carb diagrams. I know I've seen them (or links to them). Judging by the sounds of your symptoms, my guess is that you are missing the o-ring on the fuel/air mixture screw. Hope this helps.
Old Nov 8, 2005 | 10:53 PM
neversunk's Avatar
thanks...make sense...now I can't find the damn package with the o-ring....anybody got any suggestions? There was only one in the rebuild kit anyhow....
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
