Vibration
Old Nov 7, 2005 | 07:54 PM
OntarioHunter's Avatar
Default Vibration
My 2001 AC 500 Manual has a vibration. This apperars when idle and when moving. It seems to come from under the gas tank area but it can be felt in the handle bars .. or than this it works fine , any ideas? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 7, 2005 | 08:41 PM
swampyjunior's Avatar
Default Vibration
OntarioHunter,
The first thing that comes to my mind is that your exhaust is touching your frame. This is a common problem that you might see other posts on if you do a search of this site. Noise/vibration at low rpm under your left leg area that can vibtate through to the handlebars.
I think your problem could be that your exhaust pipe is touching the frame under the edge of the gas tank where it touches the seat. Other guys used washers at the bolt on points to space it out but I used a chunk of wood (2x4) and a small 5lb hammer to tap it over a bit and the vibration on my 03 400AC cleared right up.
So remove your seat from the bike and trace the exhaust pipe from the engine back to the muffler. If its touching your frame it shouldn't be.
Hope this helps.
Swampy
Dabears1983
Jun 23, 2015 04:59 AM
FireFighter
May 30, 2001 11:05 AM
ScoobyDFW
Apr 24, 2000 09:09 PM
Varso
Mar 14, 2000 09:46 AM
Hank
Nov 9, 1999 06:51 PM
