question bout 400ex
Old Nov 7, 2005 | 08:02 PM
RedNeckMXRider2's Avatar
Default question bout 400ex
im think about buying a 2003 400ex and i was curious to know if a 41 mm carb would work with stock motor but HMF exhaust? thanks for the help
Old Nov 7, 2005 | 10:23 PM
400EXtreme1's Avatar
it should work. What kind of carb?
Old Nov 7, 2005 | 10:24 PM
TractorPacker's Avatar
Do you have a balloon?
I personally don't think it would run that good. If you raise the compression, and change the cam, it would make that carb worthwhile.
Old Nov 7, 2005 | 10:48 PM
1BAD250R's Avatar
41mm seems excessive on a fairly stock EX. I know that on a 2-stroke, if you have too large of a carb it can hurt your bottom end power. I would assume the same in your case.
Old Nov 8, 2005 | 06:46 PM
thanks for the advise i just wanted to get more power from it without having to go into the motor
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
