spray on bedliner on wheels?
Old Nov 8, 2005 | 12:54 AM
dczys's Avatar
Default spray on bedliner on wheels?
i was just thinkng using spray on bedliner stuff on your atv wheels, i think blacked out wheels make look neat with some texture. and if there old and dont look good it would be an improvment.. just a thought,, idk
what ya think
Old Nov 8, 2005 | 01:00 AM
tyler711's Avatar
That sounds kind of cool. I don't know how they'd hold up, though - you might want to paint the wheels black first so if the rubber peels it wouldn't show so bad. Would you have it sprayed with Rhino or Line-x, or would you use one of those DIY kits?
I thought about painting my stockers black awhile ago, but decided against it because I figured they'd peel.
Old Nov 8, 2005 | 01:33 AM
dczys's Avatar
ya man i really dont know what would happen just a thought, someone out there give it a try, i am gunna do my racks with some spray on.. ill let ya know how it goes..
Old Nov 8, 2005 | 01:37 AM
tyler711's Avatar
I think I've heard of that before, I'd imagine that to be a good idea. Mine are getting pretty beat up.
But the wheel idea is an interesting one, I know a guy on another board that owns a Line-X shop, I'll ask him about next time I talk to him.
Old Nov 8, 2005 | 01:59 AM
Polaris500HO4x4's Avatar
Rhyno spray on would work great for your racks... it would give it a nice texture also, make sure there is no loose particles on your racks before spraying on the liner
Old Nov 8, 2005 | 08:14 AM
spyder6's Avatar
any type of spray on lining requires a few steps first hand. by the way, Line-X spray in looks the best and has higher quality, stay away from rhino, it melts in high heat.
anyway, before being applied, the surface of the metal is roughed up with high grit wet/dry sandpaper, cleaned up with alcohol, taped off, then sprayed in, the stuff has to dry for atleast 48 hours before being used
Old Nov 8, 2005 | 11:15 AM
springtuckyn's Avatar
I painted my rack with Duraliner (see my pics). I also did my bumpers on my 700 EFI. To my suprise both applications went very well. You can brush or spray it on. I thought about doing the wheels, but haven't done it yet. In doing the wheels I'd make sure to either have the wheels blasted, or go over them thoroughly with a Scotchbrite pad.
Old Nov 8, 2005 | 11:17 AM
conig's Avatar
I used the DIY stuff on my three wheelers stock wheels some time ago. I had two the held up nicely and didn;t chip in about 3 months of use. one that would peel off in sheets I do not know why. I scuffed and followed the same process. for all three rims
Old Nov 8, 2005 | 11:29 AM
CORRECTION: I used Herculiner...(http://www.herculiner.com/) not Duraliner. Still holdin up good...
Old Nov 8, 2005 | 12:43 PM
Hotdogmb's Avatar
I was thinking of using this stuff on the nerf bar tubes on my Chev Blazer ZR2 and maybe the front push/brush guard. Has anyone done this with good results?? The salt that they put on the roads up here is unreal!! Will the spray liner stuff hold up good against the salt and other road hazards well??
Thanks EH!![img]i/expressions/face-icon-small-happy.gif[/img]
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
bvolks
Sep 13, 2015 12:57 PM
meddy0388
Sep 9, 2015 06:41 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
